2013 Nissan Altima Interior Door Handle Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide is to help demonstrate how to properly replace a 2013 Altima interior door handle.
The door handle is important because it allows you easy access to get in and out of your vehicle. With this problem, you will have to find alternatives to get out of your car or worse, overpay a company for a $20 fix. You will only need a flathead screwdriver, a 10 mm socket and wrench, and a new handle.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Use an opening tool or spudger to gently pry open the cover behind the door handle.
Use a 10 mm socket to remove the bolt under the handle cap.
Use an opening tool or spudger to pry the window and door lock assembly up and free from the frame.
Use a 10 mm socket to remove the single bolt underneath the control assembly.
There is another screw located underneath the long arm panel (to the left of the door handle), unscrew it.
Unscrew the three silver screws directly behind the door handle (Top, left, right).
Hook the lock/unlock wires back into the door handle. (Handle will not work unless this step is complete.
Plug in the window control panel and place the panel back in its respectful place.
Insert the screw beneath the control panel and the screw to the right of the lock/unlock button.
Next, place both the door arm and window control panel in their place. The arm should snap in while the control panel sits flush in place.
Lastly, place the screw back in its respective place and tighten it with the rachet.
Finishing result: The older interior handle is in my hand, while the new interior handle is in place.
Eine weitere Person hat diese Anleitung absolviert.
