Zum Hauptinhalt wechseln
2013-Present Nissan Sentra Windshield Wiper Blades Replacement
Victor Kwan
Victor Kwan und eine weitere beteiligte Person
Zuletzt aktualisiert am May 28, 2024
3 - 5 Minuten
Leicht
This guide provides a step-by-step instructions for replacing the pinch tab windshield wiper blades on your 2017 Nissan Sentra.
Regular maintenance of your wiper blades is crucial for optimal visibility while driving. It is recommended to replace the wiper blades every six months or if you notice any signs of wear such as reduced contact with the windshield, squeaking, smearing, or streaking.
Follow these steps to ensure a smooth and effective process.
Before you begin the repair, turn off your car and put it in park to ensure safety.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement, Windshield Wiper Blades: Schritt 1, Bild 1 von 2 2013-Present Nissan Sentra Windshield Wiper Blades Replacement, Windshield Wiper Blades: Schritt 1, Bild 2 von 2
    • Measure the length of the wiper blade using the measuring tape or check in the owners manual for the proper size.
    • This is to make sure that you buy the right length size for your vehicle wiper blades.
  2. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 2, Bild 1 von 1
    • Gently lift up both wiper blades.
  3. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 3, Bild 1 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 3, Bild 2 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 3, Bild 3 von 3
    • Pinch both sides of the latch and lift it up to unlock the blade.
  4. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 4, Bild 1 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 4, Bild 2 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 4, Bild 3 von 3
    • Pull down the wiper blade to disengage the hook.
    • Raise the wiper blade along the arm to remove it.
  5. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 5, Bild 1 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 5, Bild 2 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 5, Bild 3 von 3
    • Retrieve the new wiper blade.
    • Pull the wiper blade down onto the arm.
    • Raise the wiper blade up, allowing it to attach to the hook.
  6. 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 6, Bild 1 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 6, Bild 2 von 3 2013-Present Nissan Sentra Windshield Wiper Blades Replacement: Schritt 6, Bild 3 von 3
    • Gently push the latch onto the wiper blade.
    • You should hear a "click" sound when it is locked.
Abschluss
Repeat the steps on the other windshield wiper to fully complete the replacement.
Victor Kwan
133 Reputation
1 Anleitung geschrieben
York University, Team 2-17, O'Regan Winter 2024 Mitglied von York University, Team 2-17, O'Regan Winter 2024
YORK-O'REGAN-W24S2G17
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 28
Letzte 30 Tage: 100
Insgesamt: 510
