2013-Present Nissan Sentra Windshield Wiper Blades Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide provides a step-by-step instructions for replacing the pinch tab windshield wiper blades on your 2017 Nissan Sentra.
Regular maintenance of your wiper blades is crucial for optimal visibility while driving. It is recommended to replace the wiper blades every six months or if you notice any signs of wear such as reduced contact with the windshield, squeaking, smearing, or streaking.
Follow these steps to ensure a smooth and effective process.
Before you begin the repair, turn off your car and put it in park to ensure safety.
Was du brauchst
Ersatzteile
Werkzeuge
Measure the length of the wiper blade using the measuring tape or check in the owners manual for the proper size.
Pull down the wiper blade to disengage the hook.
Raise the wiper blade along the arm to remove it.
Retrieve the new wiper blade.
Pull the wiper blade down onto the arm.
Raise the wiper blade up, allowing it to attach to the hook.
Repeat the steps on the other windshield wiper to fully complete the replacement.
