2014 Nissan Murano Headlight Replacement
Einleitung
Zu Schritt 1 der AnleitungIf the headlight has burnt out or broken on your 2014 Nissan Murano, use this guide to replace it. All that is required is to pop the hood, locate the headlight compartment, and replace an old headlight bulb with a brand-new one.
Before beginning, turn off the car, place it in park, and engage the parking brake.
Was du brauchst
Werkzeuge
Open the hood using the lever under the steering wheel on the driver's side.
Check to make sure the new headlight is working by starting your car and turning on your lights.
