Zum Hauptinhalt wechseln
2016 Nissan Versa Brake Light Replacement
Abdi Ahmed
Abdi Ahmed und eine weitere beteiligte Person
Zuletzt aktualisiert am June 30, 2021
10 - 30 Minuten
Mittel
Use this guide to replace your brake light for 2016 Nissan Versa.
Brake lights are compulsory safety component of your car and are legally required to be functioning whenever your vehicle is operational. This guide will provide an easy-to-follow instructions to replace this vital safety component.
Before beginning, make sure to switch off your car.
In step 5, you will need to begin prying the lens from the tip before pulling it out completely. It will be the same when you are putting the lens back on. You will need to snap the plastic tip in first in step 11 before pushing the rest of the lens in.
  1. 2016 Nissan Versa Brake Light Replacement, Brake Light: Schritt 1, Bild 1 von 1
    • Turn off the vehicle and let it cool down for 10 minutes.
    • Open the trunk.
  2. 2016 Nissan Versa Brake Light Replacement: Schritt 2, Bild 1 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 2, Bild 2 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 2, Bild 3 von 3
    • Remove the two plastic pins holding the plastic trunk cover using the flathead screwdriver.
  3. 2016 Nissan Versa Brake Light Replacement: Schritt 3, Bild 1 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 3, Bild 2 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 3, Bild 3 von 3
    • Peel away the trunk cover to reveal the two bolts holding the lights.
  4. 2016 Nissan Versa Brake Light Replacement: Schritt 4, Bild 1 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 4, Bild 2 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 4, Bild 3 von 3
    • Using the 10 mm socket and socket wrench, remove the two bolts holding the lens.
  5. 2016 Nissan Versa Brake Light Replacement: Schritt 5, Bild 1 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 5, Bild 2 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 5, Bild 3 von 3
    • Gently pry open the lens using the flathead screwdriver.
    • Using your hands, pull away the lens slowly.
    • Don't use too much force to pull the lens out as it may disconnect the electric cord or break the lens.
  6. 2016 Nissan Versa Brake Light Replacement: Schritt 6, Bild 1 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 6, Bild 2 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #3 screwdriver, remove the two screws holding the bulbs.
  7. 2016 Nissan Versa Brake Light Replacement: Schritt 7, Bild 1 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 7, Bild 2 von 3 2016 Nissan Versa Brake Light Replacement: Schritt 7, Bild 3 von 3
    • Gently take out the inner cover holding the bulbs.
    • Use both hands when separating the lens from the bulbs. Use one hand to hold the inner cover of the bulbs while the other holds the lens.
  8. 2016 Nissan Versa Brake Light Replacement: Schritt 8, Bild 1 von 2 2016 Nissan Versa Brake Light Replacement: Schritt 8, Bild 2 von 2
    • Take out the brake bulb by pushing it down and turning it counter-clockwise at the same time.
  9. 2016 Nissan Versa Brake Light Replacement: Schritt 9, Bild 1 von 2 2016 Nissan Versa Brake Light Replacement: Schritt 9, Bild 2 von 2
    • Put the new brake light in and secure it by pushing it down and turning it clockwise.
    • Test the new light by turning the car on before moving to the next step.
    • Don't forget to switch off the car once you finish testing the light.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Abdi Ahmed
196 Reputation
1 Anleitung geschrieben
York University, Team S1-G1, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G1, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G1
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 65
Insgesamt: 3,895
