Zum Hauptinhalt wechseln
8BitDo Ultimate Wireless Joystick Module Replacement
Was du brauchst
  1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: Schritt 1, Bild 1 von 2 8BitDo Ultimate Wireless Joystick Module Replacement, Case: Schritt 1, Bild 2 von 2
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Frag FixBot
    Kommentar hinzufügen
  2. 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 2, Bild 1 von 2 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 2, Bild 2 von 2
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Frag FixBot
  3. 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 3, Bild 1 von 3 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 3, Bild 2 von 3 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Frag FixBot
  4. 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 4, Bild 1 von 3 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 4, Bild 2 von 3 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 4, Bild 3 von 3
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Frag FixBot
  5. 8BitDo Ultimate Wireless Joystick Module Replacement, Joystick's Module: Schritt 5, Bild 1 von 1
    • Grip each analog stick cap firmly and pull straight up to remove them.
    Frag FixBot
  6. 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 6, Bild 1 von 2 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 6, Bild 2 von 2
    • Remove the three 5 mm Phillips #00 screws securing the midframe to the back shell, then lift it straight out.
    Frag FixBot
  7. 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 7, Bild 1 von 2 8BitDo Ultimate Wireless Joystick Module Replacement: Schritt 7, Bild 2 von 2
    • Turn to the backside of the circuit board for clear access to the solder joints.
    • Desolder all of the outlined solder joints.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 Mitglied von UMass Dartmouth, Team 1-3, Biswokarma Spring 2026
UMASSD-BISWOKARMA-S26S1G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 56
Insgesamt: 176
