Zum Hauptinhalt wechseln
ASUS ROG G46VW Indicator Lights Replacement
Nicolas Catano
Nicolas Catano und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 15, 2024
15 Minuten
Mittel
Action Shots
Bessere Einleitung
Fehlende Angaben
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ASUS ROG G46VW Indicator Lights Replacement, RAM: Schritt 1, Bild 1 von 2 ASUS ROG G46VW Indicator Lights Replacement, RAM: Schritt 1, Bild 2 von 2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Indicator Lights Replacement: Schritt 2, Bild 1 von 1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Indicator Lights Replacement: Schritt 3, Bild 1 von 2 ASUS ROG G46VW Indicator Lights Replacement: Schritt 3, Bild 2 von 2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Indicator Lights Replacement: Schritt 4, Bild 1 von 1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Indicator Lights Replacement: Schritt 5, Bild 1 von 1
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Indicator Lights Replacement, Speaker Cover: Schritt 6, Bild 1 von 1
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Indicator Lights Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Indicator Lights Replacement, Keyboard: Schritt 8, Bild 1 von 1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Indicator Lights Replacement: Schritt 9, Bild 1 von 1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Indicator Lights Replacement: Schritt 10, Bild 1 von 1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Indicator Lights Replacement: Schritt 11, Bild 1 von 1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Indicator Lights Replacement: Schritt 12, Bild 1 von 2 ASUS ROG G46VW Indicator Lights Replacement: Schritt 12, Bild 2 von 2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Indicator Lights Replacement, Indicator Lights: Schritt 13, Bild 1 von 1
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  14. ASUS ROG G46VW Indicator Lights Replacement: Schritt 14, Bild 1 von 1
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  15. ASUS ROG G46VW Indicator Lights Replacement: Schritt 15, Bild 1 von 1
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
Abschluss
Nicolas Catano
104 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 406
