Zum Hauptinhalt wechseln
ASUS ROG G46VW Motherboard Replacement
Ruben Olivares
Ruben Olivares und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 21, 2025
45 - 50 Minuten
Mittel
Action Shots
Bessere Einleitung
Keep close track of your screws and where they came from while disassembling due to the number of screws that are going to be removed in this guide.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ASUS ROG G46VW Motherboard Replacement, RAM: Schritt 1, Bild 1 von 2 ASUS ROG G46VW Motherboard Replacement, RAM: Schritt 1, Bild 2 von 2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Motherboard Replacement: Schritt 3, Bild 1 von 2 ASUS ROG G46VW Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Motherboard Replacement, Speaker Cover: Schritt 6, Bild 1 von 1
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Motherboard Replacement, Keyboard: Schritt 8, Bild 1 von 1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Motherboard Replacement: Schritt 12, Bild 1 von 2 ASUS ROG G46VW Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Motherboard Replacement, Screen: Schritt 13, Bild 1 von 2 ASUS ROG G46VW Motherboard Replacement, Screen: Schritt 13, Bild 2 von 2
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Motherboard Replacement: Schritt 14, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Gently pull the white connector until it comes loose.
  17. ASUS ROG G46VW Motherboard Replacement, Indicator Lights: Schritt 17, Bild 1 von 1
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  18. ASUS ROG G46VW Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  19. ASUS ROG G46VW Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
  20. ASUS ROG G46VW Motherboard Replacement, Motherboard: Schritt 20, Bild 1 von 1
    • Locate and remove the screws.
    • Removing the screws allows you to lift up the motherboard
  21. ASUS ROG G46VW Motherboard Replacement: Schritt 21, Bild 1 von 1
    • After lifting the motherboard up you can replace any component on it, such as the fans.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 2,174
