Einleitung
In this guide, we will replace the screen of the Asus ROG G750JW-RS72-CB.
Was du brauchst
With your finger, push this slide to the right. The battery should pop out of place.
Lift up the flap using a plastic opening tool.
Hold the flap back with your finger.
Unscrew the 5.2mm screws holding the hard drive in place.
Gently pull the rubber hard drive mount to the side.
Pull the drive out.
Remove the 8.5mm screws holding the bottom half of the laptop together.
Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
Detach the screen from the hinges of the laptop.
Gently unplug the cables connecting the screen to the motherboard.
The display assembly can now be freely separated.
5 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
