ASUS ROG Zephyrus M15GU205L Fan Cleaning
Einleitung
Zu Schritt 1 der AnleitungCleaning the fans on your ASUS ROG Zephyrus M15 GU205L is an essential maintenance task to ensure optimal performance and prevent overheating. Dust and debris can accumulate over time, hindering the airflow and causing the fans to work harder. Here's a step-by-step guide to help you clean the fans:
Was du brauchst
Werkzeuge
Mehr anzeigen …
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the 8-pin battery that secures the battery to the motherboard.
In diesem Schritt verwendetes Werkzeug:Microfiber Cleaning Cloths$3.99
Use the microfiber cloth to wipe any surface dust off the fan fins.
