Zum Hauptinhalt wechseln
ASUS ZenPad S 8.0 Front Facing Camera Replacement
John Astfanous
John Astfanous und 2 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
5 Minuten
Leicht
Empfohlene Anleitung von Studierenden
If your front facing camera does not work, you can use this guide to take your device apart and replace it. Make sure the battery is completely removed before working on the camera as to prevent shorts in the circuitry As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: Schritt 1, Bild 1 von 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: Schritt 1, Bild 2 von 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: Schritt 1, Bild 3 von 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 2, Bild 1 von 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 3, Bild 1 von 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 3, Bild 2 von 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 4, Bild 1 von 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: Schritt 5, Bild 1 von 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: Schritt 5, Bild 2 von 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
Abschluss
John Astfanous
987 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 2-2, Cagle Fall 2016 Mitglied von USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,367
