Acer Chromebook 15 C910-C453 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the battery in the Acer Chromebook 15 C910-C453.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
Sixteen 5mm Phillips screws located around the border.
Two 5mm Phillips screws located in center.
Remove the back cover by carefully prying each side with an iFixit Opening Tool.
Set aside back cover.
Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
8 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
