Zum Hauptinhalt wechseln
Acer Chromebook 15 C910-C453 Fan Replacement
Jacob Rakestraw
Jacob Rakestraw und 4 weitere Mitwirkende
Zuletzt aktualisiert am October 13, 2019
10 Minuten
Mittel
If your Chromebook is overheating, it may be a good idea to replace the fan.
Was du brauchst
Ersatzteile
Werkzeuge
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mehr anzeigen …
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook 15 C910-C453 Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 3, Bild 2 von 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: Schritt 6, Bild 1 von 1
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: Schritt 8, Bild 1 von 1
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team S15-G1, Banghart Spring 2017 Mitglied von Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 535
