Einleitung
Situations where your Chromebook is unable to display wireless settings or is experiencing dropped connections, is commonly a sign that your Wi-Fi card in the device is faulty and needs to be replaced. This guide will walk you through replacing the Wi-Fi card in your Acer Chromebook 15 CB3-532-C6T1.
Prior to beginning the repair, be sure your Chromebook is powered off and is not plugged into the wall charger.
Was du brauchst
Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
