Zum Hauptinhalt wechseln
Acer Chromebook C710-2847 Back Cover Replacement
Bradley Pavy
Bradley Pavy und 5 weitere Mitwirkende
Zuletzt aktualisiert am March 2, 2021
2 Minuten
Leicht
Removing the back cover exposes all the internal components of the laptop. Removing the back cover will void your warranty, so use caution not to damage any of the components inside.
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook C710-2847 Back Cover Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C710-2847 Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: Schritt 3, Bild 1 von 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C710-2847 Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Bradley Pavy
1.257 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-3, Forte Fall 2013 Mitglied von Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 6,390
