Acer Chromebook C730-C4V9 Keyboard Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide shows the steps on how to replace a keyboard in an Acer Chromebook C730 Series. (C730-C4V9)
PLEASE NOTE: The Chromebook Keyboard isn't supposed to be replaced! This guide involves breaking plastic clips to successfully replace the keyboard! It is recommended to replace individual keys or purchase a new device but if you wish to keep your Chromebook or the keyboard is too far gone, follow this guide.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Flip the device over and remove the twelve screws.
Using a spudger slowly pry the case open by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
Remove the USB Ribbon cable by opening the connector on the motherboard and sliding the cable out.
Remove the two screws on the sides of the battery.
Carefully slide the battery forward and the lift up
Unplug the battery from the motherboard to prevent shortages.
Remove the screw from the Wi-Fi chip
Unplug the aerials
Slide the chip away from the motherboard
Remove the screen cable by using the tab and pulling up.
Remove the track pad cable by opening the connector and sliding the cable away from the motherboard.
Remove the keyboard cable by opening the connector and sliding it away from the motherboard.
The speaker cable can be a bit tricky, with the assistance of the plastic opening tool, pull/pry the plug towards you (Carefully!)
Using the plastic opening tool, slide it under the right hinge and lift the hinge up so its not sitting on the motherboard.
Remove the five screws holding the motherboard in.
Lift the motherboard up slowly.
Using the plastic opening tool, insert it under the speakers in the middle and pry them up
While holding your thumbs on the hinges to keep them in place, open the screen slowly
Once the screen is almost flat you should feel the hinges come loose.
Lift the screen up from the body and it should separate.
Work your way along the edges of the plate and attempt to remove the top off every single pen if possible.
After removing as many pins as possible work your way around the plate and pry it up.
Start working your way under the plate to disconnect it from the keyboard.
Work your way along the edges of the keyboard and attempt to remove the top off every single pen if possible.
Do not cut the pins that stick out above the keyboard, these are for the motherboard plate.
After you have removed the top off every pin, using the plastic opening tool work your way around the keyboard, it should lift right out.
Place the new keyboard in the frame and ensure it is sitting nicely.
Once in place, using a hot glue gun start putting small drops of glue on the pins you cut off the keyboard.
Avoid gluing the pins that are risen! This will affect the fitment of the motherboard plate.
Work your way around the plate putting glue on the plastic pins.
Put a dab of glue at the top and bottom of the speaker (Where the old double sided tape is)
Place speaker into position.
2 weitere Personen haben diese Anleitung absolviert.
