Acer Chromebook C740-C4PE Solid State Drive Replacement
10 Minuten
Leicht
Einleitung
Zu Schritt 1 der AnleitungThis guide will show you how to change the Solid State Drive in Acer Chromebook C740-C4PE.
Was du brauchst
Werkzeuge
Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
Use the spudger or any other prying tool to pry the back plate off of the device.
Fast fertig!
Abschluss
