Einleitung
The internal speakers inside of the Acer Chromebook CB315-3HT-C3FQ can only work when the diaphragms inside the speakers are able to vibrate without anything restricting their movement. If no other solutions to any sound problems are working, then that means that the diaphragms are blocked or damaged. Use this guide to get into the Chromebook and inspect the speakers.
Was du brauchst
Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
Unplug the speaker cord from the motherboard's port.
Remove the speakers from the laptop.
Eine weitere Person hat diese Anleitung absolviert.
