Zum Hauptinhalt wechseln
Acer Iconia Tab A501 Battery Replacement
Trey Bazinet
Trey Bazinet und 6 weitere Mitwirkende
Zuletzt aktualisiert am May 16, 2024
5 - 15 Minuten
Leicht
Empfohlene Anleitung von Studierenden
Batteries tend to lose capacity over time as they are used and eventually fail. If your battery won’t hold a charge or can’t power your device, you may decide to replace the battery. This guide will demonstrate battery replacement for the Acer Iconia Tab A501.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Acer Iconia Tab A501 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Iconia Tab A501 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Iconia Tab A501 Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Battery Replacement: Schritt 2, Bild 1 von 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Take off any tape covering the battery or black battery-motherboard cable.
  4. Acer Iconia Tab A501 Battery Replacement: Schritt 4, Bild 1 von 3 Acer Iconia Tab A501 Battery Replacement: Schritt 4, Bild 2 von 3 Acer Iconia Tab A501 Battery Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  5. Acer Iconia Tab A501 Battery Replacement: Schritt 5, Bild 1 von 2 Acer Iconia Tab A501 Battery Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
  6. Acer Iconia Tab A501 Battery Replacement: Schritt 6, Bild 1 von 1
    • Take out the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 26
Insgesamt: 688
