Zum Hauptinhalt wechseln
Adjusting Contrast on TI-Nspire Calculator
Alan Wong
Alan Wong und 3 weitere Mitwirkende
Zuletzt aktualisiert am February 19, 2016
1 - 2 Minuten
Sehr einfach
If your calculator does not appear to light up, it could be that the contrast is at a low setting. Use this guide to aid you in adjusting the contrast.
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: Schritt 1, Bild 1 von 2 Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: Schritt 1, Bild 2 von 2
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. Adjusting Contrast on TI-Nspire Calculator: Schritt 2, Bild 1 von 3 Adjusting Contrast on TI-Nspire Calculator: Schritt 2, Bild 2 von 3 Adjusting Contrast on TI-Nspire Calculator: Schritt 2, Bild 3 von 3
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
Abschluss
Now you should have the image contrast set to your preferences.
Eine weitere Person hat diese Anleitung absolviert.
Alan Wong
63 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-52, Forte Fall 2012 Mitglied von Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 5,989
