Anker Soundcore Motion Boom A3118 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungReplacing the battery in an Anker Soundcore Motion Boom A3118 speaker can rejuvenate its performance when the original battery fails to hold a charge. Working in a static-free environment is essential to avoid damaging the internals. Proper disconnection and reconnection of the battery are crucial for a successful replacement.
Was du brauchst
Use the metal spudger to remove the left and right shells surrounding the subwoofer.
Use the metal spudger to remove the front speaker grille.
Remove eight 15 mm screws located in the four corners of each front speaker using a Phillips #1 screwdriver.
Remove all eight internal 15 mm screws from around the front speakers using a Phillips #1 screwdriver.
Tear off the padding on the top of the speaker with your hands.
Remove the three 15 mm screws located on the top of the speaker using a Phillips #1 screwdriver.
Disconnect the speaker's white power cord from the motherboard.
Disconnect the rest of the cords connected to the motherboard.
Remove the three 15 mm screws using a Phillips #1 screwdriver from the bottom left and right sides of the motherboard.
Remove the entire motherboard from the speaker.
Remove the five 10 mm screws from the motherboard using a Phillips #0 screwdriver.
Separate the battery from the motherboard.
Tear off the sticky padding from the battery.
The battery is now free and able to be replaced.
Eine weitere Person hat diese Anleitung absolviert.
