Zum Hauptinhalt wechseln
Asus G53JW-A1 Battery Replacement
Tim Cedar
Tim Cedar und eine weitere beteiligte Person
Zuletzt aktualisiert am December 31, 2018
10 Sekunden
Sehr einfach
This guide shows how to remove or replace the battery of an Asus G53JW-A1 computer. This may be necessary if the battery is worn out or damaged, and removing the battery is also sometimes necessary in order to replace other components.
  1. Asus G53JW-A1 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Asus G53JW-A1 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Start with the laptop upside-down.
    • Turn the laptop so that the battery is facing you.
  2. Asus G53JW-A1 Battery Replacement: Schritt 2, Bild 1 von 3 Asus G53JW-A1 Battery Replacement: Schritt 2, Bild 2 von 3 Asus G53JW-A1 Battery Replacement: Schritt 2, Bild 3 von 3
    • Look to the right of the battery for a small black switch.
    • Slide the right side switch to the right, away from the battery.
    • When the switch is in the correct position, a red sticker will be visible underneath the switch.
    • On the left side of the battery is another black switch. Slide this to the left, away from the battery, and hold it in place there.
    • The left side switch does not have a red sticker underneath.
    • Slide the battery towards yourself.
Abschluss
0 Kommentare
Kommentar hinzufĂŒgen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 270
