Asus G55VW DS71 Back Panel Replacement
Einleitung
Zu Schritt 1 der AnleitungIn order to start replacing the internal components of the computer, the backpanel and battery will need to be removed. This guide will teach you on how to properly dismantle those parts.
Was du brauchst
Make sure the computer is off and turn it over on its back.
Push the slider all the way back until the compartment for the battery opens. Simply remove the battery and place it aside.
Find the panel on the back of the computer. Using a screwdriver with a SQ0 head, unscrew the 2 screws on that panel.
Lift up the panel at the indent and place it aside.
