Zum Hauptinhalt wechseln
Asus G74SX-BBK7 Trackpad Button Replacement
Ryan Lawrence
Ryan Lawrence und 3 weitere Mitwirkende
Zuletzt aktualisiert am June 24, 2015
15 - 20 Minuten
Mittel
The mouse button, located under the trackpad, includes a left and right side and is used for clicking on a computer. It can be extremely inconvenient to not have. This guide will teach you replace your mouse button.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 2, Bild 1 von 1
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 3, Bild 1 von 2 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 3, Bild 2 von 2
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: Schritt 4, Bild 1 von 1
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 5, Bild 1 von 1
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 6, Bild 1 von 2 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 6, Bild 2 von 2
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 7, Bild 1 von 3 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 7, Bild 2 von 3 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 7, Bild 3 von 3
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 8, Bild 1 von 2 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 8, Bild 2 von 2
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 9, Bild 1 von 3 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 9, Bild 2 von 3 Asus G74SX-BBK7 Trackpad Button Replacement: Schritt 9, Bild 3 von 3
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ryan Lawrence
611 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-10, Maness Spring 2015 Mitglied von Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Where did you find the part?
websmiths - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 25
Insgesamt: 4,887
