Asus GL551JW-AH71 Display Assembly Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide outlines how to replace the display assembly for the Asus GL551JW-AH71.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
Flip the laptop on the right side while still holding the upper and lower assemblies close together.
Unplug the display connector from the motherboard.
Remove the upper assembly.
Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
Using a plastic opening tool, separate the bezel from the screen.
Insert the tool and slide it right to left to release the bezel from the screen.
3 weitere Personen haben diese Anleitung absolviert.
