Asus GL551JW-AH71 Optical Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide outlines how to remove the optical drive in the Asus GL551JW-AH71. This guide also serves as a prerequisite for guides that require the removal of the back cover.
Was du brauchst
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
Eine weitere Person hat diese Anleitung absolviert.
