Asus GL551JW-AH71 RAM Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide outlines how to replace the RAM in the Asus GL551JW-AH71.
Was du brauchst
Werkzeuge
Using a Phillips #00 screwdriver, remove the two 11mm screws that hold the access panel in place.
Locate the tabs holding the RAM chip in place.
Push the tabs in an outward direction from the RAM and the RAM will be released.
Gently remove the RAM from the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
