Zum Hauptinhalt wechseln
Asus GL551JW-AH71 Upper Assembly Replacement
William Kelley
William Kelley und 2 weitere Mitwirkende
Zuletzt aktualisiert am August 19, 2019
20 Minuten
Mittel
This guide outlines how to remove the upper assembly from the Asus GL551JW-AH71. This guide primarily serves as a prerequisite for guides that require the removal of the upper assembly to access the motherboard, fan and display cables.
Was du brauchst
Werkzeuge
  1. Asus GL551JW-AH71 Upper Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 2, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 2, Bild 2 von 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 3, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 3, Bild 2 von 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: Schritt 4, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: Schritt 4, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 5, Bild 1 von 3 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 5, Bild 2 von 3 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 5, Bild 3 von 3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 6, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 6, Bild 2 von 2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: Schritt 7, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: Schritt 7, Bild 2 von 2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 8, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 8, Bild 2 von 2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 9, Bild 1 von 2 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 9, Bild 2 von 2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 10, Bild 1 von 1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 11, Bild 1 von 3 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 11, Bild 2 von 3 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 11, Bild 3 von 3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 12, Bild 1 von 3 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 12, Bild 2 von 3 Asus GL551JW-AH71 Upper Assembly Replacement: Schritt 12, Bild 3 von 3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
William Kelley
1.035 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 536
