Zum Hauptinhalt wechseln
Asus MeMO Pad 7 ME170C  Motherboard  Replacement
Tatiana Schneider
Tatiana Schneider und 11 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
15 Minuten
Mittel
Falsche Werkzeuge
Benötigt Bessere Bilder
Aus eins mach mehr
The motherboard is where all of the action takes place. It connects you to the internet and video streaming as well as running electricity to other parts of the device including the speakers and battery.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: Schritt 1, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: Schritt 1, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 2, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 2, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 2, Bild 3 von 3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 3, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 3, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 4, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 4, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 5, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 5, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 6, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 6, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 6, Bild 3 von 3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 7, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 7, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 8, Bild 1 von 2 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 8, Bild 2 von 2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 9, Bild 1 von 2 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 9, Bild 2 von 2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 10, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 10, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 10, Bild 3 von 3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 11, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 11, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 11, Bild 3 von 3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 12, Bild 1 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 12, Bild 2 von 3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 12, Bild 3 von 3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 13, Bild 1 von 2 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: Schritt 13, Bild 2 von 2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
You are amazing!! Please make the tutorial "how change ASUS ME170 Touch Screen Digitizer". Thanks!!!
Walter Tejerina - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 18
Insgesamt: 3,391
