Zum Hauptinhalt wechseln
Asus MeMO Pad 7 ME170C Front Facing Camera Replacement
Thomas Brooks
Thomas Brooks und 2 weitere Mitwirkende
Zuletzt aktualisiert am August 29, 2018
15 - 20 Minuten
Mittel
Falsche Werkzeuge
Benötigt Bessere Bilder
Aus eins mach mehr
The front facing camera is used to take photos from the tablets front orientation. The camera may stop taking photos and videos clearly. This can be replace fairly easily, but the motherboard needs to be removed first.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Motherboard: Schritt 1, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Motherboard: Schritt 1, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 2, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 2, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 3, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 3, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 4, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 4, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 5, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 5, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 6, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 6, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 6, Bild 3 von 3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 7, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 7, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 8, Bild 1 von 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 9, Bild 1 von 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 9, Bild 2 von 2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 10, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 10, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 10, Bild 3 von 3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 11, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 11, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 11, Bild 3 von 3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 12, Bild 1 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 12, Bild 2 von 3 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 12, Bild 3 von 3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 13, Bild 1 von 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: Schritt 13, Bild 2 von 2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
  14. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Front Facing Camera: Schritt 14, Bild 1 von 1
    • Gently wedge plastic prying tool underneath top edge of camera.
    • Try not to bend or scratch anything on the motherboard when handling.
    • Pry camera upward away from motherboard.
    • Camera should pop off easily.
Abschluss
Thomas Brooks
301 Reputation
3 Anleitungen geschrieben
IUPUI, Team S3-G3, Wilson Spring 2017 Mitglied von IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 228
