Zum Hauptinhalt wechseln
Asus MeMO Pad 8 ME181C Battery Replacement
Amy Clarke
Amy Clarke und 5 weitere Mitwirkende
Zuletzt aktualisiert am September 2, 2018
2 - 3 Minuten
Mittel
Anleitung eines Community-Mitglieds
Use this guide to replace a faulty battery in you ASUS MeMO Pad 8.
Was du brauchst
Werkzeuge
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  1. Asus MeMO Pad 8 ME181C Battery Replacement, Rear Case: Schritt 1, Bild 1 von 2 Asus MeMO Pad 8 ME181C Battery Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Asus MeMO Pad 8 ME181C Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Asus MeMO Pad 8 ME181C Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Asus MeMO Pad 8 ME181C Battery Replacement: Schritt 3, Bild 1 von 2 Asus MeMO Pad 8 ME181C Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Asus MeMO Pad 8 ME181C Battery Replacement: Schritt 4, Bild 1 von 2 Asus MeMO Pad 8 ME181C Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Asus MeMO Pad 8 ME181C Battery Replacement: Schritt 5, Bild 1 von 2 Asus MeMO Pad 8 ME181C Battery Replacement: Schritt 5, Bild 2 von 2
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Amy Clarke
223 Reputation
2 Anleitungen geschrieben
iFixit, Team 1-1, Wacker Spring 2016 Mitglied von iFixit, Team 1-1, Wacker Spring 2016
FIX-WACKER-S16S1G1
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Great instructions and easy disassembly/reassembly. Photos really helped!
Joe Martin - Antwort
The time and difficulty for doing this and the me176cx should be the same.
P Schmied - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 5,279
