Asus MeMO Pad HD 7 Speaker Assembly Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will direct you in replacing the entire speaker assembly for the tablet. The guide will require a few simple steps and removing a few small screws form the device.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Unlock the ZIF connectors on the data cables.
Remove the cable from its slot by gently pulling downward on the tabs.
Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Unscrew two Philip's #000 2 mm screws located on the left and right side of the speaker housing.
Locate the speaker wires to the left side of the battery. Remove the connector by pulling up gently or prying with a tool if you can not get a good grip.
Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the logic board.
Using a spudger, carefully pry the GPS antenna from the bottom of the speaker housing.
With the GPS antenna removed from the bottom of the speaker housing it can be removed from the device.
3 weitere Personen haben diese Anleitung absolviert.
