Zum Hauptinhalt wechseln
Asus Q534U Wi-fi card Replacement
Eric Okoko
Eric Okoko und 7 weitere Mitwirkende
Zuletzt aktualisiert am September 15, 2020
10 - 15 Minuten
Mittel
If your Asus laptop (Q534U) is having problems connecting to WiFi, then the solution may be as simple as switching out a faulty WiFi card. First, be sure to eliminate all the possible errors with the laptop. Once the problem has been narrowed down to the WiFi card, use this guide to walk you through the steps of changing the WiFi card. This fix should not take more than 20 minutes, and only requires removal of parts.
It does require removing the battery, so use caution as a punctured battery can cause a dangerous fire.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Asus Q534U Wi-fi card Replacement, Back Case Removal: Schritt 1, Bild 1 von 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Wi-fi card Replacement: Schritt 2, Bild 1 von 2 Asus Q534U Wi-fi card Replacement: Schritt 2, Bild 2 von 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U Wi-fi card Replacement: Schritt 3, Bild 1 von 2 Asus Q534U Wi-fi card Replacement: Schritt 3, Bild 2 von 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U Wi-fi card Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U Wi-fi card Replacement, Wi-Fi card: Schritt 5, Bild 1 von 1
    • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Needle nose pliers can be used as a detaching tool.
  6. Asus Q534U Wi-fi card Replacement: Schritt 6, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Pull the WiFi card out of the socket toward the fan housing.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Eric Okoko
327 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 3,000
