Zum Hauptinhalt wechseln
Asus Q552UB-BHI7T12 RAM Replacement
Alexander Boettcher
Alexander Boettcher und 10 weitere Mitwirkende
Zuletzt aktualisiert am June 22, 2022
5 - 10 Minuten
Leicht
Benötigt Bessere Bilder
RAM (Random Access Memory) is also known as system memory. Generally, 12 GB (8 GB and 4 GB) RAM is given by default with the Asus Q552UB-BHI7T12 Laptop. But users can upgrade up to 16 GB using two 8 GB RAMs. Normally the user needs to change the RAM when its performance degrades therefore the system becomes slower. But before changing the RAM, an Asus Q552UB-BHI7T12 user needs to confirm here that it’s actually the RAM which is causing the problem, not the CPU or Graphics Card.
Use this simple guide to replace your Asus Q552UB-BHI7T12 RAM. Follow these three simple steps which will take no longer than 10 minutes.
  1. Asus Q552UB-BHI7T12 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Asus Q552UB-BHI7T12 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • On the bottom of the laptop, gently pull the wire connecting the battery to the motherboard
  2. Asus Q552UB-BHI7T12 RAM Replacement: Schritt 2, Bild 1 von 1
    • Gently lever the two arms securing the RAM toward either side of the laptop, while holding the RAM in place with your thumbs.
  3. Asus Q552UB-BHI7T12 RAM Replacement: Schritt 3, Bild 1 von 1
    • Carefully slide the ram with your index fingers from in between the white tabs.
Abschluss
To reassemble device, follow the instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 952
