Zum Hauptinhalt wechseln
Asus ROG G56JK CD Drive Replacement
Brandon Wells
Brandon Wells und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2019
25 - 30 Minuten
Mittel
Benötigt Mehr Bilder
Fehlende Schritte
Replace a broken or messed up CD-Drive.
Before starting on this guide, unplug the laptop from its charger and turn the laptop off.
Was du brauchst
Werkzeuge
  1. Asus ROG G56JK CD Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Asus ROG G56JK CD Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK CD Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK CD Drive Replacement: Schritt 3, Bild 1 von 1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK CD Drive Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK CD Drive Replacement: Schritt 5, Bild 1 von 1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK CD Drive Replacement, CD Drive: Schritt 6, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the four 4mm screws.
  7. Asus ROG G56JK CD Drive Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the CD drive out of the side of the laptop and remove it from the device.
Abschluss
Brandon Wells
253 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 792
