Zum Hauptinhalt wechseln
Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement
Cameron Richard
Cameron Richard und 4 weitere Mitwirkende
Zuletzt aktualisiert am November 18, 2022
20 Minuten
Mittel
Should you find yourself needing to increase storage capacity or experiencing a faulty Solid State Drive (SSD) in your Asus ROG Strix GL702VM-BHI7N09 gaming laptop, this guide will be useful. The SSD is vital for system operation and is required for storing the programs and operating system on your computer.
Was du brauchst
Komplettpaket für die Reparatur
Diese Kits enthalten alle Ersatzteile und Werkzeuge, die für diese Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement, Back Panel: Schritt 1, Bild 1 von 2 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement: Schritt 2, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement: Schritt 2, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement: Schritt 2, Bild 3 von 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement, Battery: Schritt 3, Bild 1 von 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement: Schritt 4, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement: Schritt 4, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement, Solid State Drive: Schritt 5, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement, Solid State Drive: Schritt 5, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Solid State Drive Replacement, Solid State Drive: Schritt 5, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the 4mm screw holding down the SSD.
    • Slide the SSD out from the connection slot.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,034
