Einleitung
The display for the tablet is one of the hardest parts to replace as it is attached by glued and you will need a hair dryer. The broken screen affects the display's functionality and will need replacement.
Ersatzteile
Keine Ersatzteile angegeben.
Disconnect the dock and make sure the power is turned off.
Use plastic opening tool to pry screen up and remove from outer casing.
Pull up on the black circuit board protector.
Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
Use the same screwdriver to remove two 3mm screws connecting the clips.
Use tweezers to remove two wires connected from the battery to the motherboard.
Use the spudger to remove the battery from the case.
Use a Phillips #00 Screwdriver to remove the 3mm screws that connect the metal board with the screen.
Use a hairdryer on high and heat the edges of the screen. Melt the adhesive holding the screen to the casing of the tablet.
Take out the display away from the screen.
