Zum Hauptinhalt wechseln
Asus TUF Gaming FX505DY Heat Sink & Fan Replacement
Sebastian Frederick Klincewicz
Sebastian Frederick Klincewicz und 3 weitere Mitwirkende
Zuletzt aktualisiert am April 13, 2023
Keine Schätzung
Mittel
Bessere Einleitung
Fehlende Angaben
Was du brauchst
Werkzeuge
  1. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 2, Bild 1 von 2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 3, Bild 1 von 2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 4, Bild 1 von 2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 4, Bild 2 von 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: Schritt 5, Bild 1 von 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: Schritt 5, Bild 2 von 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: Schritt 5, Bild 3 von 3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  6. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 6, Bild 1 von 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 6, Bild 2 von 3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: Schritt 6, Bild 3 von 3
    • Disconnect two power cables connecting fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 78
Insgesamt: 1,985
