Asus Transformer Pad Infinity Charging Port Replacement
Einleitung
Zu Schritt 1 der AnleitungReplacing the charging port involves opening up the device. Prerequisites; follow the Asus Transformer Pad Infinity Teardown link up to step 6 to remove the charging port.
Disconnect the long silver ribbon connector from the screen.
Remove the orange ribbon connector with the two connections.
Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
Eine weitere Person hat diese Anleitung absolviert.
