Asus VivoTab RT TF600T Screen charging port Replacement
Einleitung
Zu Schritt 1 der AnleitungIf your Asus Vivo Tab is not charging and you have ruled out the charger then this guide is for you. This guide will instruct you on how to remove and replace the charging port inside the tablet portion of your Asus Vivo tab.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
Now that the screen is completely detached, lay the back panel flat on a smooth surface.
Lift the screen to view the inside of the tablet.
Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
Rotate the tablet clockwise, so the charging port is turned towards you.
Remove the two 0.79 mm #00 screws from the charging port with the Philips #00 Screwdriver.
Place the plastic opening tool behind the charging port, closest to the outer edge of the device.
Gently pry the charging port away from the frame.
Remove the eleven 0.79 mm #000 screws around the motherboard with the Phillips #000 screwdriver.
Use the nylon or metal spudger to help pry the motherboard from the back panel.
Once the mother board is relieved from the glue, use your hand to lift the motherboard up and to the opposite end of the back panel.
Flip up the white lever with the plastic opening tool to release the connection.
Gently remove the charging port ribbon piece from the motherboard. It should come out easily using your fingers.
Eine weitere Person hat diese Anleitung absolviert.
