Zum Hauptinhalt wechseln
Canon EOS 60D LCD Screen Swivel Assembly  Replacement
Alejandro Cabrera
Alejandro Cabrera und 4 weitere Mitwirkende
Zuletzt aktualisiert am August 27, 2021
20 - 40 Minuten
Mittel
If the LCD swivel stops turning, or is broken by the user, this guide will help you replace it. Special care should be taken when disconnecting the LCD connector from the motherboard.
Was du brauchst
Werkzeuge
  1. Canon EOS 60D LCD Screen Swivel Assembly  Replacement, Rear LCD Screen Dissasembly: Schritt 1, Bild 1 von 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 3, Bild 1 von 2 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 3, Bild 2 von 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D LCD Screen Swivel Assembly  Replacement, Removing Rear Cover: Schritt 5, Bild 1 von 2 Canon EOS 60D LCD Screen Swivel Assembly  Replacement, Removing Rear Cover: Schritt 5, Bild 2 von 2
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 6, Bild 1 von 2 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 6, Bild 2 von 2
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 7, Bild 1 von 1
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 8, Bild 1 von 2 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 8, Bild 2 von 2
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 9, Bild 1 von 2 Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 9, Bild 2 von 2
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 10, Bild 1 von 1
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 11, Bild 1 von 1
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 12, Bild 1 von 1
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
  13. Canon EOS 60D LCD Screen Swivel Assembly  Replacement, LCD Screen Swivel Assembly: Schritt 13, Bild 1 von 1
    • Carefully pry off the LCD screen connector up from the motherboard to disconnect it, using the plastic opening tool.
  14. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 14, Bild 1 von 1
    • Remove one 2.8 mm Phillips #PH00 black screw on the side of the swivel assembly by using the PH00 screwdriver.
  15. Canon EOS 60D LCD Screen Swivel Assembly  Replacement: Schritt 15, Bild 1 von 1
    • Remove the two 2.8 mm Phillips #PH00 black screws on the back of the swivel assembly using the PH00 screwdriver.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 16-6, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
anybody know how to fix the conection that make the screen turn upside down?
yoeldiamante - Antwort
thank you for the tutorial. but it is so wrong, there is no way to reasambly following the steps backward. do it for your self and you will see. there are skipping steps in the disassembly. carefoul anybody who follow this tutorial. i got lost in the reasambly. hope to can figure it out.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 39
Letzte 30 Tage: 82
Insgesamt: 11,472
