Zum Hauptinhalt wechseln
Canon EOS 60D Rear LCD Screen Replacement
Alejandro Cabrera
Alejandro Cabrera und 2 weitere Mitwirkende
Zuletzt aktualisiert am February 1, 2020
Keine Schätzung
Mittel
If you drop the camera and break the LCD screen, or if the screen just stops functioning, this guide will help you replace it.
Be sure to use a magnetic mat or small container for your screws, as they are very small and easy to misplace.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen Dissasembly: Schritt 1, Bild 1 von 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Replacement: Schritt 3, Bild 1 von 2 Canon EOS 60D Rear LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: Schritt 5, Bild 1 von 2 Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: Schritt 5, Bild 2 von 2
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 16-6, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 54
Insgesamt: 8,207
