Zum Hauptinhalt wechseln
Canon EOS Rebel T1i Camera Battery Notch Replacement
Jonathan Lin
Jonathan Lin und 6 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2025
20 - 30 Minuten
Mittel
Benötigt Bessere Bilder
If your battery notch is stuck, or even broken, then follow this guide to replace the notch. All it takes is some hard work, a few tools, and the right attitude.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: Schritt 1, Bild 1 von 2 Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: Schritt 1, Bild 2 von 2
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a JIS #000 screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 2, Bild 1 von 2 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 2, Bild 2 von 2
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 3, Bild 1 von 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 3, Bild 2 von 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the bottom three 4mm screws with a JIS #000 screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the inner 4mm screw with a JIS #000 screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 5, Bild 1 von 2 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 6, Bild 1 von 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 6, Bild 2 von 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 7, Bild 1 von 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 7, Bild 2 von 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: Schritt 7, Bild 3 von 3
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Jonathan Lin
548 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 3-41, Maness Spring 2014 Mitglied von Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 57
Insgesamt: 3,385
