Zum Hauptinhalt wechseln
Canon EOS Rebel T1i Front Screen Replacement
Michael Peck
Michael Peck und 8 weitere Mitwirkende
Zuletzt aktualisiert am February 6, 2020
10 Minuten
Leicht
Benötigt Bessere Bilder
This guide will take you through the steps required to change your screen and get a clear view of your picture.
Was du brauchst
  1. Canon EOS Rebel T1i Front Screen Replacement, Front Screen: Schritt 1, Bild 1 von 1
    • Clean the broken or cracked screen as best as possible.
    • Place the suction cup on the damaged screen.
  2. Canon EOS Rebel T1i Front Screen Replacement: Schritt 2, Bild 1 von 2 Canon EOS Rebel T1i Front Screen Replacement: Schritt 2, Bild 2 von 2
    • While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
  3. Canon EOS Rebel T1i Front Screen Replacement: Schritt 3, Bild 1 von 3 Canon EOS Rebel T1i Front Screen Replacement: Schritt 3, Bild 2 von 3 Canon EOS Rebel T1i Front Screen Replacement: Schritt 3, Bild 3 von 3
    • Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture.
    • Remove the plastic screen from the camera.
    • Release the broken screen by pulling down the lever of the suction cup.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 3-41, Maness Spring 2014 Mitglied von Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Be sure to measure the size of your screen before buying the suction cups. I got the heavy-duty ones and then found that they were too big for my Rebel T1i screen.
cmorris - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 43
Insgesamt: 5,655
