Zum Hauptinhalt wechseln
Canon EOS Rebel T5 Motherboard Replacement
Was du brauchst
  1. Canon EOS Rebel T5 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Motherboard Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Motherboard Replacement: Schritt 7, Bild 1 von 3 Canon EOS Rebel T5 Motherboard Replacement: Schritt 7, Bild 2 von 3 Canon EOS Rebel T5 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  8. Canon EOS Rebel T5 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  9. Canon EOS Rebel T5 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  10. Canon EOS Rebel T5 Motherboard Replacement: Schritt 10, Bild 1 von 3 Canon EOS Rebel T5 Motherboard Replacement: Schritt 10, Bild 2 von 3 Canon EOS Rebel T5 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
  12. Canon EOS Rebel T5 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Motherboard Replacement: Schritt 13, Bild 1 von 2 Canon EOS Rebel T5 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Motherboard Replacement: Schritt 14, Bild 1 von 3 Canon EOS Rebel T5 Motherboard Replacement: Schritt 14, Bild 2 von 3 Canon EOS Rebel T5 Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Austin Tucker
1.003 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 16-4, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
This guide is amazing, but if you change the mainboard do you have to initialize it by software, like Spt?
Edgar Nunes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 42
Insgesamt: 3,729
