Canon EOS Rebel T5 SD Card Board Replacement
Einleitung
Zu Schritt 1 der AnleitungIf your camera is no longer reading SD cards, you may find that you need to replace your card reader. This guide will show you the steps necessary.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
Lift the now free card/battery door to reveal the battery compartment.
Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
Turn the camera so that the back is facing to your right.
Remove the 5mm JIS #000 screw above the rubber USB port cover.
Remove the rubber piece.
Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
Turn your camera so that the bottom is facing you.
Remove the 5mm JIS #000 screws.
Now turn the camera so that the front is facing towards your right.
Remove the two remaining 5mm JIS #000 screws.
Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
Gently pry the back panel from the main body of the camera.
Remove the four silver 4mm JIS #000 screws connecting the LCD screen to the back of the camera.
Be sure to lift the ribbon cable to remove the remaining hidden black 4mm JIS #000 screw.
Remove all ribbon cables with the plastic spudger.
Gently pry up the black plastic tabs to slide out the ribbon cables
Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
Turn your camera so that the top is facing you.
Remove the two black 5 mm JIS #000 screws.
Turn the grip side toward you.
Remove the rubber grip, using the plastic spudger.
Remove the five silver 5mm JIS #000 screws.
The motherboard can now be removed.
Using a pair of tweezers, remove the tape covering the SD card board ribbon cable.
Using the plastic spuger, lift up the black locking tab on the SD card board ribbon cable and disconnect the ribbon cable.
Remove the three 3mm JIS #000 screws connecting the SD card reader to the back of the device.
Carefully lift the SD card board out of the camera.
7 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Removal of the sensor is NOT required to take the SD board out of the camera. The sensor needs to be fitted back to exactly the same height, otherwise you WILL not retain autofocus. Why was there no mention of this during the steps above?
Bonjour , ou peut on acheter le lecteur de carte sd , merci , cordialement
Step 19 and 20 are only for modifiing or replacing the image sensor
And is not recommended because AF doesn't work without further adjustment
