Zum Hauptinhalt wechseln
Canon EOS Rebel T6i Flash Assembly Replacement
Shane Riding
Shane Riding und 12 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
1 Stunde
Schwierig
If the flash of your Canon Rebel T6i (also known as model EOS 750D) is malfunctioning — not producing any light or not triggering when taking a picture — use this guide to remove and replace the entire flash assembly.
Make sure to check the flash settings on your camera and confirm that the flash assembly is faulty. The camera flash should trigger when the camera mode is set to Automatic (A+) and the scene you are photographing is very dark.
Before beginning, remove the battery from your camera and disconnect from from any external power source.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 1 von 3 Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 2 von 3 Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 3 von 3
    • Remove two 6.8 mm JIS #000 screws on the right side.
    • Remove six 5.3 mm JIS #000 screws on the bottom.
    • Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
  2. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 2, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove one 5.9 mm JIS #000 screw on the top right.
    • Remove one 3.4 mm JIS #000 screw on the top left.
  3. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 3, Bild 1 von 3 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 3, Bild 2 von 3 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 3, Bild 3 von 3
    • Using a metal spudger, pry the rubber grip off of the casing on the left side of the camera.
    • Potential for device damage: Be careful not to rip the rubber with the metal spudger.
    • Remove five silver 5.8 mm JIS #000 screws from underneath the grip.
  4. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 4, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 4, Bild 2 von 2
    • Using the metal spudger, pry the rubber grip located just below the turndial.
    • Potential for device damage: Be careful not to rip the rubber.
  5. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 5, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 5, Bild 2 von 2
    • Carefully use the plastic opening tool to pry the casing apart along the seam.
    • Follow the seam with the plastic tool until the back is ready to remove.
    • Potential for device damage: Make sure you use the grounding strip to remove the chance of discharging static electricity into the internal components.
  6. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 6, Bild 1 von 3 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 6, Bild 2 von 3 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 6, Bild 3 von 3
    • Notice the two connections attaching the back of the camera to the motherboard.
    • To disconnect the white wire, pinch the wire casing and pull it directly out from the camera.
    • This may take a very small amount of strength; however, do not force or pry it.
    • To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
    • Once removed, set the back in a safe place.
  7. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 7, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
    • Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
  8. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 8, Bild 1 von 1
    • Remove the button cell battery from the motherboard using a pair of tweezers.
  9. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 9, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
    • Disconnect the three ribbon connectors along the top.
    • Don't detach the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
  10. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 10, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 10, Bild 2 von 2
    • Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
    • Remove the four screws from the bottom of the camera.
  11. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 11, Bild 1 von 3 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 11, Bild 2 von 3 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 11, Bild 3 von 3
    • Using the plastic opening tool, pry the front of the casing off of the camera.
    • Warning: Electric Shock! Be careful not to touch the terminals of the capacitor (black cylinder). This can cause the capacitor to discharge.
  12. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 12, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 12, Bild 2 von 2
    • Remove the yellow and red connections on the front near the black cylinder (capacitor).
    • The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
    • The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
  13. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 13, Bild 1 von 1
    • Remove the diopter adjustment knob next to the viewfinder using a JIS #000 screwdriver.
  14. Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 14, Bild 1 von 2 Canon EOS Rebel T6i Flash Assembly Replacement: Schritt 14, Bild 2 von 2
    • Remove the entire upper flash assembly by gently pulling it up and off the camera.
    • The flash assembly is sold as a single piece.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Shane Riding
861 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 61
Insgesamt: 3,743
