Canon PowerShot A2200 Back Cover Replacement
Einleitung
Zu Schritt 1 der AnleitungThis replacement guide requires you to remove the screws that hold the back cover of the camera in place. This will allow you to replace the back cover as well as have access to other parts of the camera.
Was du brauchst
Werkzeuge
Mehr anzeigen …
First, remove the batteries and memory card.
Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
Begin taking off the back cover with a plastic opening tool.
Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
Continue taking off the back cover along the left side of the camera as seen in the third picture.
Use the plastic opening tool to separate the top section of the back cover from the frame.
Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
