Zum Hauptinhalt wechseln
Canon PowerShot A2500 Body Casing and Faceplate Replacement
James Hickey
James Hickey und 4 weitere Mitwirkende
Zuletzt aktualisiert am March 6, 2020
2 - 5 Minuten
Leicht
The Canon Powershot is made of a plastic casing that holds all of the internal parts inside. This is the prerequisite for any other repairs or replacements. Ensure to be careful when disassembling the camera.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: Schritt 1, Bild 1 von 2 Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: Schritt 1, Bild 2 von 2
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 2, Bild 1 von 1
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 3, Bild 3 von 3
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 4, Bild 1 von 3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 4, Bild 2 von 3 Canon PowerShot A2500 Body Casing and Faceplate Replacement: Schritt 4, Bild 3 von 3
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
James Hickey
393 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 3-4, Duarte Spring 2015 Mitglied von UMass Dartmouth, Team 3-4, Duarte Spring 2015
UMASSD-DUARTE-S15S3G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 459
