Canon PowerShot A590 IS Back Cover Replacement
Einleitung
Zu Schritt 1 der AnleitungYou will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
Was du brauchst
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
8 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
